10-08-2015, 03:40 AM #1
- Sep 2015
- 6
Overextrusion - How to adjust filament feedrate?
I believe I'm getting some overextrusion I've seen a tutorial where the guy sets the printer to feed a 100mm length of filament and then measures how much actually passed through the extruder.
Where do I find the settings page to do this? is it in the Slicing software or a printer firmware setting?
I have
Sailfish 7.6
Slic3r
Makerware
RepG
10-08-2015, 09:41 AM #2
Did you try a Smaller nozzle size ?
What size are you using now?
We found that a .3mm size works best with our printer.
Sometime the Actual nozzle opening is Not what it's supposed to be
so we use drill-bits to measure new nozzles.
You can purchase Sets of various size nozzles at eBay, at low cost.
10-08-2015, 11:29 AM #3
BTW: I've seen a test like that for a filament 'Making' extruder,
but Not for a Printer extruder.
10-09-2015, 06:57 AM #4
- Sep 2015
- 6
Thanks, It has the nozzle it came with 0.4 I was unaware you could chop/change nozzles around (still very much a noob to all this) I'll look into it.
This is the Tutorial I was referring to, http://www.instructables.com/id/How-...ur-3d-Printer/ I don't know if its even possible to access the settings that are shown on a CTC with Sailfish. I looked through RepG but couldn't find anything similar, was hoping someone had been down this path before.
thanks.
