Results 1 to 10 of 18
10-06-2015, 07:22 AM #1
- Oct 2015
Do we even need to buy printers anymore? Is 3D Hubs the future of mass printing?
Do you think that 3D printing for most people will be sending a design for someone else to print for them, or is 3D Hubs' success only temporary until printers become cheaper and easier to use?
We are conducting research on the members of 3D Hubs so if you have a hub there, please answer our survey !
We really need your input, and it only takes 2 minutes.
Link to our survey: http://goo.gl/forms/ebnjKbVup7
Remember, sharing is caring!
Best,
Adrian
10-06-2015, 07:29 AM #2
- Oct 2015
Interesting survey, it raised some new points for me. I think 3D Hubs is a perfect platform for 3D printing to be spread to the average user. At the stage 3D printers are today, for most people it does not make sense to buy their own printer. I would advice beginners to first order a few prints through the hub, before making the investment.
Good luck ! Would love to see your findings once you're done.
10-06-2015, 09:26 AM #3
- Sep 2015
- 9
I will use them while I set up my own, will use them to test my Metal coating system I am building
10-06-2015, 10:47 AM #4
For most 3D printer users it's a Learning, Creative and Fun 'Hobby' !
It's No longer a 'Hobby' if you have someone else Do it For you !
And there's really no Need for it to be Other than a Hobby,
when nearly everything that can be 3D-printed can also be purchased in Molded or Machined form
for less money and more accurately,
unless it is a new design creation or Art-form, which again is usually a Hobby.Last edited by EagleSeven; 10-06-2015 at 10:54 AM.
10-06-2015, 10:58 AM #5
well 3d hubs certainly isn't an answer. Haven't had anything through them yet, or even looked like it :-)
Plus even 3d hubs makes things pretty expensive. When you can buy a decent working fully built machine for £329, anyone who is likely to use 3dhubs for more than one print - will most likely just buy their own printer.
So rather than printing services being the end of the desktop machine - I think the cost of them will actually excourage more people to buy their own printer.
And pretty much 100% of what I print can't be bought as an injection moulded thing.
10-07-2015, 08:51 AM #6
- Oct 2015
I think it will be important to distinguish between 3D printing as a hobby and as a way to sporadically getting things printed because you actually need something. For me, it will be really interesting to see how the technology can move away from being a hobby to having more applied value for the mass market. Surely, we would expect application areas for consumers to soar as the technology becomes more readily available - wouldn't you agree?
10-07-2015, 08:55 AM #7
- Oct 2015
I can see how the cost of printing may not in all cases be the reason for using 3D Hubs - but what about the complexity of use? 3D printing may not be rocket science, but I would argue that it's not enough 'plug-and-play' for the mass to adopt...
10-07-2015, 09:21 AM #8
Yes, but the primary limiting factor of 3D-printed 'Functional' objects, (not Art objects),
is that they are Not as Strong and Durable as same type parts made by Molding or Machining.
And I doubt 3D technology will ever advance to the Same Durability level.
I think 3D printing will become an even greater Creative Artist Tool though
10-07-2015, 09:33 AM #9is that they are Not as Strong and Durable as same type parts made by Molding or Machining.
If you configure the print properly parts should be more durable and stronger while also being lighter.
The ability to alter the interior density and configuration of the interior of an object make things more durable than solid parts.
Solid parts will shatter because shockwaves propagate quickly through solid medium.
The same part made with a non-solid interior and strong skin, will not shatter as shockwaves do not propagate well through voids.
Also a non-solid part will have better flex.
Also the sheer variety and strength of available fff filaments - from super strong nylons to incredibly tough flexible materials means that you can more easiily tailor the material and print settings to an object.
If you print it correctly and understand how changing layers and infill changes the final objects properties - then you should be producing parts every bit as strong - and in most cases, more durable - than injection moulded parts.
If you can't use a machine properly - don't blame the machine.
10-07-2015, 09:39 AM #10
