Results 41 to 50 of 63
09-29-2015, 11:51 PM #41
- Feb 2015
- 211
09-30-2015, 07:07 PM #42
- Dec 2014
- Canada
- 498
ok I got it working!
the heatsink i got with it is comicaly huge lol.
oh well this thing wasnt going to win any beauty awards anywaysignore the nest of wires20150930_194510.jpg
09-30-2015, 07:39 PM #43
- Jul 2014
- 305
I also have mine working and it has been printing for 4 hours with no issues.
I am happy to report printing with PID enabled and with the heat bed off I am getting the same results; in other words no banding.
09-30-2015, 08:45 PM #44
- Feb 2015
- 371
I am having some problems since implementing the ssr. Not sure if it is that, or the new power supply. I suspect the power supply. Got the 79amp model linked earlier in the thread.
The he issue I am having is the print just stopping. I am running the prints from the sad card. It is like the printer is being momentarily reset. The print just stops and reverts to a state it enters when you first power up.
I havent witnessed this this first hand yet so I am just speculating. I had a few small prints work fine with the ssd before the new power supply was installed. This is why I am leaning towards the new supply being the culprit.
09-30-2015, 11:46 PM #45
- Feb 2015
- 211
10-01-2015, 07:07 AM #46
- Feb 2015
- 371
Thanks for the sympathy. He he. I probably cause more problems stumbling around then anything else. Things are much easier to diagnose when there is a pattern. This issue has no pattern I can see. Some print fine, some don't.
My last 8 hour print completed without issue. Looks pretty good. I'll keep printing away and see if I can notice a pattern. Also, the power supply I bought was linked to in a different thread. It is a bit overkill, 75 amp server supply relabeled as a Juice Box from Ebay. I will keep an Eye on it.
10-01-2015, 09:21 PM #47
- Feb 2015
- 371
Print tonight failed. Gotta to figure this out! I checked all the wires and they look fine. Is there anything in the firmware or code that could cause this? Perhaps the power supply is the culprit.
10-01-2015, 10:26 PM #48
- Jul 2014
- 305
10-02-2015, 07:06 AM #49
- Feb 2015
- 371
Yes, it is holding steady at 12.4 during the prints.
10-02-2015, 11:45 AM #50
- Feb 2015
- 211
