DjPrinter is right. Your temperature is way too high. Try reducing your temperature at an interval of 5 degrees until you achieve your desired 3d print quality.
not sure, I mean I am using the same temps as before the rebuild, could it be he nozzle is damaged or the aluminum block is out of position from when I put it back together?
