Results 21 to 27 of 27
09-18-2015, 05:46 AM #21You can go pretty fast for travel only moves (120mm/s),
09-18-2015, 11:35 PM #22
- Sep 2015
- South Australia
- 89
Ok so now I have really done it! Switched to a new PLA filament yesterday and everything is clogged! I have tried Geoff’s idea of the flush out, not working, looks like some disassembly is required today! I am going to start with the feeding mechanism,
are they any videos online of hot end disassembly?
09-19-2015, 04:11 AM #23
- Sep 2015
- South Australia
- 89
Hi All, here are some photos of my journey today, I tore down the extruder assembly, and found some real nasties in there!
you can see in the images there is a heap of blue PLA filament and white PLA in the other extruder, I wonder if the PLA was melting to early and hence started clogging things up?
I still have blocked hot ends nozzles, and I am not sure how to dissamble these and clean them I wonder if the Teflon tiube is clogged, if anyone could give me some advice it would be most appreciated! I have read they need to be hot to get the nozzels off, I tried it when it was cold, to no avail
I am thinking of putting it all back to together again and cracking the heat up to 250 and see if that flushes them, what do you think?
clogged hot end.jpgburnt nozzles.jpgExtruder 0.jpgextruder 1 b.jpgextruder 1.jpg
i get the feeling also if the bed is not level the plastic builds up in side the nozzle?Last edited by anthony27; 09-19-2015 at 07:33 AM.
09-20-2015, 06:16 AM #24
- Sep 2015
- South Australia
- 89
Ok so I think I found the culprit of all my problems!
I have always suspected the bed to be higher on the lft side and I have confirmed why this is!
the left hand adjustment screw is threaded, hence I could never get the left side to go lower as I could only turn it so much,
this is a manufacturing fault, wonder if they will replace my dual extruders for me??
since they are now destroyed from all the nozzle clog repairs, see images attached
09-24-2015, 08:05 PM #25
- Aug 2015
- 256
Excellent video on cleaning the extruder: https://www.youtube.com/watch?v=vmIY9_6s8Ss
09-24-2015, 08:11 PM #26
- Aug 2015
- 256
Do you mean the thread were stripped? That sux, but ttill I would think it would be obvious that the build plate wasn't level, the paper test doesn't lie. You can't really blame FF if you operated the printer with an unlevel plate.
One thing to keep in mind is that the leveling screws all interrelate, meaning you may need to adjust the other two screws to get one screw just right. This is especially true of a three point leveling system. Raising and lowering any of the screws also raises and lowers the other points by a smaller amount. So if one is really out of whack it's necessary to adjust the others to get it right.
09-24-2015, 09:34 PM #27
- Sep 2015
- South Australia
- 89
Ah yes of course Hindsight is a blessed thing djprinter
