Results 1 to 10 of 14
09-24-2015, 01:13 PM #1
- Aug 2015
- 29
Cura with Flashforge Creator Pro?
I'm trying some alternatives because ReplicatorG is cranky and VERY slow to generate gcode.
Has anyone got Cura working? I'm getting errors like this:
Changing monitoring state from 'Offline' to 'Opening serial port'
Connecting to: /dev/cu.usbmodemfd121 with baudrate: 115200 (fallback)
Connected to: Serial<id=0x1064b85d0, open=True>(port='/dev/cu.usbmodemfd121', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=3, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from 'Opening serial port' to 'Detecting baudrate'
Trying baudrate: 250000
Send: M105
Unexpected error while reading serial port: SerialException: 'device reports readiness to read but returned no data (device disconnected?)' @ machineCom.pyo:_readline:516
Changing monitoring state from 'Detecting baudrate' to 'Error: SerialException: 'device reports re...'
Connection closed, closing down monitor
09-24-2015, 01:27 PM #2
- Burnley, UK
- 1,662
Repg does not generate Gcode. I use Cura and then RepG to convert it to X3G file.
It is all I use.
Cura will not talk to your printer at all.
09-25-2015, 09:36 AM #3
- Aug 2015
- 31
slic3r is free and decent.
simplify3d cost but is better.
09-28-2015, 03:31 AM #4
09-28-2015, 03:32 AM #5
Easiest alternative for FF creator series printers is Makerware.
09-28-2015, 04:23 AM #6
- Burnley, UK
- 1,662
09-28-2015, 05:28 AM #7
don't think repg has been updated for a decade or two :-)
I honestly couldn't stand how slow it slices.
But makerware is reasonable.
During the period I was waiting for a 3D printer I tried most of them and liked cura the most.
But simplify3d is hands down the best and if you print more than one thing a week - it's well worth the money.
09-28-2015, 09:00 AM #8
RepG is, to my understanding, a front-end for Skeinforge and (a very ancient) Slic3r. So yeah, it can export both g-code and x3g.
I only used it to access settings in the firmware and do the dual nozzle calibration. Oh yes, and I use it to convert g-code output from Slic3r to x3g when I play around with Slic3r. Its not really good for anything else...
09-28-2015, 09:02 AM #9
09-28-2015, 11:19 AM #10
- Feb 2015
- 91
Don't use cura to talk directly to the printer. The thing that doesn't read gcode directly is your printer. Makerbots and clones use x3g protocol. Use cura to do the slicing and then use gpx or RepG to convert the gcode to x3g for the SD card. You'll particularly need to get the start and and gcode to be correct for your printer.
