Thread: Is This CoreXY?
09-22-2015, 10:19 PM #1
- Dec 2014
- Canada
- 498
Is This CoreXY?
I am working on a New printer. I saw someone that was using a belt layout similar to this.
but im not sure it qualifies as CoreXY or Hbot or some variant of either
Thoughts?
09-22-2015, 11:25 PM #2
- new jersey
- 752
it was my understanding that on a core xy at some point the belts cross over themselves. im sure there are many ways to skin a cat so maybe not in every configuration but on any core xy i have seen they always cross.
09-22-2015, 11:54 PM #3
- Dec 2014
- Canada
- 498
Here is another version. where there is a belt loop on top and bottom. no cross over. but does this still qualify as CoreXY with its advantages or Hbot?
09-23-2015, 01:06 AM #4
09-23-2015, 01:59 AM #5
I think the important part of the coreXY thing is that the carriage moves on both X and Y while the 2 motors stay stationary.
The belt arrangement is irrelevant.
09-23-2015, 11:36 AM #6
- Dec 2013
- Georgia
- 934
Well, the belt arrangement is what differentiates between the CoreXY, the HBot and the Sli3Dr gantries. HBbot has a problem with causing the x-axis to try to twist out of position and on a flimsy frame (like you would find on many Reprap builds) can rack the entire frame out of square. Sli3Dr has completely seperated x and y axes, making it run on standard Cartesian coordinates, but it also uses double the length of belt that the CoreXY does, allowing it to strech more over time.
All that said, the placement of the motors on their respective belts in a CoreXY is totally interchangeable, and the belts on this are indeed in the CoreXY configuration.
New member with print issue
