09-19-2015, 02:14 PM #1
- Sep 2015
- 28
New FF Creator Pro just arrived the courier story, toolhead offset, jog
Hello, my new baby just arrived yesterday and was a little damaged by the courier in the transport
one of the leg was seriously damaged and Z axis out of the top holder, all of this is fixed by myself until now
and it is as new again, z axis wasn't bend or anything so it seams to be OK!
The only strange things I've noticed is when I using the JOG function from the menu or RepG software
and I move the X to very left or Y to very front the step motor still going and jumping for as long as I keep the button pressed
is this normal ?
second thing, my printer was shipped with Sailfish 7.7 atmega2560 but the settings in the Homing/VREFs are only
X Home Offset 151.998
Y Home Offset 74.995
pot x 118
pot y 118
pot z 40
pot A 118
pot B 118
all the other are set to 0
is this normal as well ?
As I can see some ffCpro using also X toolhead offset at around 33.79 but in my it is 0
I have updated my printer now to the latest revision of 7.7 sailfish with no problems
but all the offset are taken from the original firmware it was shipped with r01234
so there is no difference
I have done my first test print (TEST RIGHT) from the included SD card it looks ok as for the first print without a proper calibration
as you can see there is a strange (for me) vertical line on the left from the middle i don't know if this is a problem with the object itself, calibration or something completely else.
thank you!
firstprintpla.jpgLast edited by obecny; 09-19-2015 at 04:43 PM.
09-19-2015, 04:45 PM #2
- Sep 2015
- 28
this model above was printed in PLA now trying ABS, will see...
09-19-2015, 05:16 PM #3
- 93
the virtical line i common as thats where the circle starts and ends every line so it will create a line there some softwares have a random start point to overcome that issue.
09-19-2015, 05:37 PM #4
- Sep 2015
- 28
Thanks for a quick answer
I have my dial indicator holder printed in ABS now, S3D medium quality 0,2mm there is some small hole on the top next to the slot for the indicator have no clue why this is happened
also the lines on the top are very visible but I believe this is because of the 0.2 mm layer but in general it looks OK, it was just 27 minutes print
photos are not great but I have a little dark here and the model is small
thank you
