Results 11 to 20 of 23
09-16-2015, 07:54 AM #11
09-16-2015, 08:24 AM #12
09-16-2015, 08:25 AM #13
09-17-2015, 06:40 AM #14
This seems like it would be fairly easy to do in Sketchup. Import the STL, (You'll need a plugin for that), and clean up any loose junk hanging from underneath. Drop a line from each corner to a common rectangle beneath, forming your base plate. Then use Solid inspector (another plugin) to find any extra/missing geometry. Export to an STL, and boom.
09-17-2015, 07:37 AM #15
Yup, that was my first thought and seems the simplest. But I've tried that, Sketchup just locks up when the .stl is imported
09-17-2015, 07:55 AM #16
Marm, that sounds pretty easy...
I've installed SketchUp and the stl plugin:
I don't have an option to import an stl:
What am I missing?
09-17-2015, 08:01 AM #17
Nothing, you need to use 'Import' not Open to read the .stil but I've tried on two machines including a powerful MacPro and SketchUp just hangs. Suspect the importer can't cope.
09-17-2015, 08:04 AM #18
That is the window from the Import menu item. Perhaps my plugin isn't plugged in properly?
09-17-2015, 09:07 AM #19
Possibly, I'm on a Mac and it's available as an option here. I auto installed mine from the Extension Warehouse.
09-17-2015, 09:42 AM #20
sketchup sucks.
Can't see it working - but you never know.
But I would like to know why s3d doesn't add any support to a floating model. That can't be right.
