Results 11 to 20 of 23
Thread: Shifting layers
09-13-2015, 11:57 AM #11
- Jul 2015
- Bergeijk, The Netherlands
- 12
Already have the Z-hop/ vertical lift in every model i try and print.
I checked the pulleys on being fixed and they where.
Which takes me to the last possible thing that it could be, the stepper drivers getting too hot.
Which would be fixed by turning down the pot-meter on the boards and putting some forced cooling on them.
But, does anyone know if there's fixed settings for the pot meters?
09-14-2015, 02:06 AM #12
why don't you put cooling fins on your motors like for a CPU ?
09-14-2015, 02:59 AM #13
- Jul 2015
- 12
On the motors? I was under the impression the drivers where overheating.
09-14-2015, 09:52 AM #14
- Aug 2014
- Montreal, Quebec
- 576
Both overheat easily, motor can go 100C+ easily and on top of that your driver can go nuts in heat too.
09-14-2015, 01:46 PM #15
- Jul 2015
- 12
Tried the longer print again today after measuring the voltage through the potmeter with a proper multimeter.
They're set to roughly 0,5V now and the extruder stepper to 0,65V with a cooling fan.
Both the stepper drivers and the stepper motors where still cool to the touch.
So any ideas on what to try next?
Any known bugs in Slic3r maybe?
09-14-2015, 05:46 PM #16
- new jersey
- 752
Ill say it again. Its highly probable that its the arduino version you are using to compile the firmware with.
Also your accelleration and or travel move speed is too high
09-14-2015, 11:13 PM #17
You're right in the appropriate range for voltages. I run .65v for my extruder motor and .5v for my xyz motors.
In my opinion you are not having motor voltage issues. Motor voltage issues usually manifest in single layer skips, then a return to normal, then maybe another single layer skip later. Essentially...occasionally step misses that are fixed on every retract. With that said...do you have retract set up in slic3r?
I've also seen shifts like this manifest from binding in carriages and belts. If you have a bind in your carriage bearings or belts somewhere that could result in what you are seeing.
09-15-2015, 03:04 AM #18
- Jul 2015
- 12
I'll try and check the version this afternoon, it'll be a first for me.
I've set up my retract to be 4,5mm, which solved a stringing problem I had before.
So I think that amount is adequate.
09-15-2015, 10:52 AM #19
- Jul 2015
- 12
09-19-2015, 10:23 AM #20
- Jul 2015
- 12
Haven't got any luck reflashing the arduino Mega, as i don't have the original firmware yet.
Tried it with a modified version of the repetier and marlin software but no luck getting it to work yet...
