08-31-2015, 04:35 AM #3
- Aug 2015
- 9
I just swapped the right extruder Steppe motor with the Y axis motor and it made zero difference.
I will now try you suggestion Mjolinor!
Thanks!
UPDATE 1
I just cut all the steppe motor cable ties and re cable tied them individually to move them away from each other
I then went into JOG mode and ran Y axis up and down 2 times, it then started to do the little stutters....follow by a lockup of the printer. It then rebooted moments later.
UPDATE 2
I just re uploaded the latest firmware (sailfish) and ran the JOG test again. It still locked up the printer when moving the Y axis HOWEVER the LCD displayed an actual error. PLATFORM FAILURE!
Anyone familiar with that error? I cant find anything on it....?
