If you want to keep cost down, avoid much of the advice suggested on this thread ..
...Check out 'Davidlaserscanner' if you don't know it already. There is a large forum and someone may be able to help you there.
David laser scanner is more expensive than Einscan and is less accurate and flexible. A little research before advising others and challenging others proposals.
