Thread: LEDs causing freeze up?
02-09-2014, 12:37 PM #1
- Feb 2014
- 11
I have a FlashForge Creator which is 99% a knock off of the Makerbot Replicator 1.
I just installed LEDs to light up the chamber, and the first two prints I tried after installing the LEDs they both froze while laying down the raft.
I used two LED strips I bought from an autoparts store that are rated for a 12v system. After reading that the best place to tap into for power was the fan - which I found mine to put out 24v - I ran the two LED strips in series to create a 12v drop across both.
The LEDs work fine, but could they be causing the machine to freeze up?
02-09-2014, 05:21 PM #2
Could they be draining too much power?
How many Watt is your PSU?
02-10-2014, 10:43 AM #3
- Feb 2014
- 11
Hmm, I'm not sure. From what I have read, LEDs do not draw much power at all - but read this:
I completely disconnected the LEDs from the printer and the issue of it freezing has gone away. So the LEDs were the problem. Why are these printers so sensitive? I've ran into issues other times of the printer freezing due to having another appliance plugged into the same outlet as the printer. Any electrical noise seems to really screw with the internal electronics.
02-10-2014, 08:44 PM #4
Bare electronic components (are on mine anyway).
Maybe add some ferrite connections on the wires.
http://www.elmac.co.uk/pdfs/ferrite.pdf
02-13-2014, 11:07 AM #5
The fan runs at various speeds, using PWM (pulse wave modulation). Your LEDs would flicker on and off at that high speed, with corresponding surges of high current. Not a good idea.
02-13-2014, 11:10 AM #6
An LED takes very little current, but 100 of them will need more than an amp.
