Results 1 to 10 of 10
Thread: Beer opener
08-27-2015, 01:46 AM #1
- Jul 2015
- 11
Beer opener
Hi!
I designed a beer opener. It is suppose to be printed in plastic, so to make it work, I made a place for 1 euro cent (for the metal part, that will open the bottle). I would like to ask if in your opinion should I print a hole like this with or without support? I cannot wait to print it and test it!
Thanks for any advice!
08-27-2015, 04:17 AM #2
Why don't you start the print,reach end of the slot, pause the print, put the coin in the slot and finish the print ? That way you've all the support you want and it's gonna stay in place.
08-27-2015, 05:18 AM #3
- Jul 2015
- 11
Hmmm... interesting idea, I didn't think about it! The problem is, that when I was pausing some print, there always a visible seam was created. For me more important is that the model will look nice from the outside and inside the hole eventually I may accept some "dirt" and try to remove it later... maybe I will try to put the coin inside without stopping the printer, but I don't know if I will succeed in this. Well and also it would be problematic to print then more than one model in time. I think for start, I will try to print it without support and see the effect. If it will be not satisfying I will try to use your idea! Thanks!
08-27-2015, 05:39 AM #4
shouldn't need support. that's a pretty small gap to bridge.
08-27-2015, 05:48 AM #5
- Jul 2015
- 11
So I decided to try it now without support. In three hours I will put here some pictures of printed models.
08-27-2015, 06:17 AM #6
three hours !
that shouldn't take more than 30 minutes to print.
what are you printing it on ?
08-27-2015, 06:27 AM #7
- Jul 2015
- 11
But I have to wait untli other print will be finished I will print it od DeGreen.
08-27-2015, 09:37 AM #8
- Jul 2015
- 11
So this is picture of my print:
Inside the hole I had to clean a little with a knife, but now it's ok and the coin is staying on place. Thank you for your help!
08-28-2015, 05:46 AM #9
08-28-2015, 06:47 AM #10
- Jul 2015
- 11
Thanks! And the most important part- it works!
