08-21-2015, 01:52 PM #1
- Aug 2015
Beeping and error code on rep rap machine
Just installed a new board as the old one broke at a connection point...
switched from the MKS board on top to the one on the bottom (only one i could order figured it would be fine)
https://youtu.be/g8Edf0CCKqo
There is a video of the problem and what happens when i give it power...if i unplug the LCD it will stop and also if i hold the reset switch it will stop....
UPDATE: unplugged all connections and only plug in the LCD and i get beeping still....the beeping coincides with a blue LED on the board itself right next to the reset switch ...even if the LCD isnt plugged in the light still flashed..Last edited by austing; 08-21-2015 at 08:13 PM.
08-22-2015, 01:17 PM #2
- Aug 2015
