08-18-2015, 04:03 AM #1
- Aug 2015
- 12
ff creator pro purge to the left simplify 3d
Ive recently got a ff creator pro and i have been only really using the right extruder , this purges off the bed to the right then starts to print , thats all good
But now I've started to use the left extruder id like to setup another FFF profile ,I've started using the left extruder for ABS and right for PLA, what i really need to know is what do i enter into the script to purge the left nozzle off the left hand side of the bed because at the moment its not purging at all , this is my script using simplify 3d
; **** Replicator 1 dual start.gcode ****
M73 P0 ; enable build progress
G162 X Y F3000 ; home XY maximum
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
M132 X Y Z A B ; recall home offsets
M135 T0 ; load right extruder offsets
G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table
G130 X20 Y20 Z20 A20 B20 ; lower stepper Vrefs while heating
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M134 T0 ; stabilize bed temperature
M104 S[extruder1_temperature] T1
M133 T1 ; stabilize left extruder temperature
G130 X127 Y127 Z40 A127 B127 ; default stepper Vrefs
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
M135 T1 ; left tool
G1 X120 Y-70 Z0.15 F1200 ; slow wipe
G1 X110 Y-70 Z0.5 F1200 ; lift
M73 P1 ;@body (notify GPX body has started)
; **** end of start.gcode ****
thanks !
08-18-2015, 04:38 AM #2
- Jun 2015
- Sydney Australia
- 36
Try the following script:
; **** Replicator 1 dual start.gcode ****M73 P0 ; enable build progress
G1 Z0 ; move Z to 0
G1 X-125 Y-70 Z30 F9000 ; move to wait position left hand side off table
M135 T1 ; left tool
G1 X-110 Y-70 E30 F300 ; move nozzle
G1 X-120 Y-70 Z0.15 F1200 ; slow wipe
G1 X-110 Y-70 Z0.5 F1200 ; lift
08-18-2015, 05:08 AM #3
- Aug 2015
- 12
03-07-2016, 02:40 AM #4
- Feb 2016
- 96
03-07-2016, 03:01 AM #5
- Jun 2015
- Sydney Australia
- 36
