Results 1 to 10 of 29
08-16-2015, 04:04 AM #10
I see some differences, but i'm not sure this is the problem:
- in screen 1, i have "Color LCD" for my Display, you have "Mobile PC Display". Your screen 1 is your Macbook screen ? or you have another external screen connected ? if you have one, disconnect it and use your Macbook as screen 1, so we have the same setup.
- in screen 2, i have LCD_VGA as display, you have Generic non_pnp monitor. Not sure if this is a problem, and i remember this seems to be in line with Einscan instructions. But who knows, maybe under bootcamp it makes a difference.
ALso, to be sure your display port, cable and projector are working, boot under OS and extend your desktop to see if you can display anything with the projector under OS.
Which display port you are using ? I0m using the one on the left, just next to the power plug, because there are 2 on that side (macbook pro retina)
Hugues
