08-13-2015, 07:50 AM #1
- Aug 2015
Flashforge Creator Pro printing surface quality
Hi guys,
I have a flashforge creator pro and I'm having a hard time trying to have a smoth surface on a small print. I tried to increase the temperature as much as I could and improved a little. Is there something else I can do to have a smooth surface?
08-13-2015, 09:13 AM #2
how small is it ?
bear in mind that the bead width is 0.4mm so you'll never get totally smooth.
Sand paper works really well though :-)
And acetone paint on abs smooths quite well. (mix acetone with the abs filament to make a thick gap filling/smoothing paint)
08-13-2015, 01:08 PM #3
- Aug 2015
So if I dissolute some filament in acetone and paint over surface after sand I may get a better result? Thanks for your help.
