Results 1 to 10 of 18
  1. #3
    suggest you pick up a raspberry pi2 and run octoprint.
    you can feed your rpi2 with either eithernet or wifi
    you can setup a usb cam and there are free android apps that let you control your printer and view the camera
    working great for me
    edit : just make sure to install the gpx plugin
    if you use slic3r you can go right from slic3r to the printer/octoprint
    if use use simplify3d, you can just turn off generate .x3g and save the gcode to your desktop and then drag and drop to your octoprint browser session.
