Thread: Need RAMPS Firmware Zip
08-08-2015, 02:44 PM #1
- Jul 2015
- 27
Hello I'm trying to get the firmware I need for my RAMPS board since I'm going to use the E3d hot end on my new i3v. I'm unable to download it from the link below Makerfarm links to. I would like the entire zip. Anybody happen to have it?
https://app.box.com/s/buudxaofad9yewn35ujvrhnuvffvoe76
08-08-2015, 04:01 PM #2
Can't help with the full zip, but the only difference for the e3d *should* be the type of thermistor for the hot end. In the following line from file configuration.h, the 1 value would change to 5 for the e3d.
#define TEMP_SENSOR_0 1
EDIT: In other words, I'm suggesting you could get by through using the firmware zip from the link for the standard firmware in the build guide, editing in the above change.Last edited by printbus; 08-08-2015 at 04:41 PM.
