Thread: Nema 17 motors
07-31-2015, 03:47 AM #1
- Jul 2015
Nema 17 motors
Hi, I'm building a Prusa i3, are good this motor?
http://it.aliexpress.com/item/5pcs-4...849871491.html
Thanks
07-31-2015, 03:55 AM #2
- Burnley, UK
- 1,662
They are OK and will work. The problems you will have with these motors are:
If the wires break you cannot replace them as they go directly into the motor, ones with plugs on are much better
The current draw per winding varies somewhat as does the pulling torque and the locking torque. This will probably not give you problems as they have plenty of power even on the weaker windings.
The stepping angle varies particularly when you are microstepping. This makes waves on your prints sometimes but is generally not too much of a problem.
Just a quick answer, I am sure there will be other input from other members.
08-02-2015, 02:06 PM #3
- Jul 2015
How are these motors? http://reprapworld.com/?products_det...4#.Vb5qNPl4uLk
they are advised in the RepRap wiki: http://reprap.org/wiki/NEMA_17_Stepper_motor
08-02-2015, 02:51 PM #4
08-02-2015, 04:11 PM #5
- Aug 2014
- Montreal, Quebec
- 576
We did use the 17hs8401 for some robotic application in our school lab. They worked well, we did use our own National Instruments stepper driver though, can't tell if it will ever make noise with those pololu drivers.
If you are in Montreal, there's a store..... the salesman is quite nice.
http://www.voxelfactory.com/collecti...motor-17hs8401
