07-30-2015, 06:28 PM #1
- Jul 2015
- 26
Filament bunching up around extruder and not sticking to bed
NEW FlashForge Creator Pro Dual
So i was very exited b/c I successfully printed 3 ABS parts with no issues at all. However,
I've been trying since yesterday to get my 4th print with no success. The filament wraps itself
around the extruder and not to the bed. See picture attached. I have checked temperatures with
my digital thermometer and it all comes to temp. Using same filament included with the bundle from FlashForge
that yielded 3 successful prints. Only change was I had to level the bed for a second time since it lost
level, from prying off the three previous prints.
Any help would be greatly appreciated.
07-30-2015, 07:31 PM #2
- May 2015
- 39
Level your bed to 1 paper height. Use hairspray or kapton tape on the bed and turn up the bed temp to 110 dec C.
07-31-2015, 04:43 AM #3
Yep, as Joop said your bed is not level.
If the nozzle is not close enough to the bed, the plastic cannot stick.. and ends up doing exactly what you pictured.
I used to level my bed and then print, now.. I just print out a random object and level the bed while it's printing, not caring about the print being finished, more just getting that first layer to print perfectly. I just find it's easier to do it all when it's all still hot and warm and less waiting for preheats.Hex3D - 3D Printing and Design http://www.hex3d.com
07-31-2015, 05:45 AM #4Only change was I had to level the bed for a second time
07-31-2015, 07:43 AM #5
- Jul 2015
- 26
07-31-2015, 07:53 AM #6
- May 2014
- 35
ABS aging
We are spoiled aren't we? All the prints I made the first month and a half where really nice but now I'm getting the same thing you are. My printer is now nearing 2 months old. I'm guessing my ABS, out for the whole time, is absorbing moisture, because it now curls back on itself, strings and doesn't stick to the build platform. I'm going to try taking the spools off and putting them in a tightly closed bin with silica (a bucket of Damp Rid, from Lowes) to see if that helps.
If this is your problem, no amount of bed leveling will fix it. Even if it starts with good adhesion, the curling back does eventually grab the object and yank it off the platform. See attached photos.
07-31-2015, 08:14 AM #7
- Jul 2015
- 26
Yes, very similar issue. However, do you think the filament would absorb that much moisture having only been out for 3 days (in my case)?? I guess it depends on your geographical location. I didn't think Dallas Tx. area was that humid, but then again it might be. It worries me if it is moisture that causes these issues. i wonder how hard
it would be to return the printer to FlashForge and get a refund and wait a couple more year till all the kinks are worked out of 3D printing.
Thanks for sharing
