07-29-2015, 07:03 PM #1
- Jul 2015
- 26
FlashForge Createro Pro - Print head
When I start a new print, the heads move to the very front left of the machine (makes a funny sound like it maxes out). How can I change it so it goes to the center of the bed??
Thanks
07-30-2015, 02:36 AM #2
07-30-2015, 11:24 AM #3
- May 2014
- 35
It's starting position, to extrude a small amount to clear the extruder, is set in your slicer. If you're using your default setup, that came with the printer, that'd be in RepG. The command would be in the gcode, and would need to be changed there before you produce an x3g. However, as Sebastian said, you don't want a big blob in the middle of your print.
07-30-2015, 06:19 PM #4
- Jul 2015
- 26
