Results 1 to 10 of 56
07-26-2015, 10:35 AM #1
- 52
That might work. The reason I was thinking ultrasonic was other sla printers print a layer, then the object moves down and up before the next layer is printed. I was guessing that this is to insure the model is coated, and break any surface tension. Ultrasonic would keep a constant ripple at a high frequency where the average wave would be the print area.
However, I like your idea better. So much simpler!
07-29-2015, 11:32 PM #2
- Jul 2015
How about if you had a speaker (audio, not ultrasonic) that would vibrate the tank between layers. So have the laser trace the pattern then turn off while the tank is shaken, wait a short time for settling (avoiding ripples) and then do the next layer?
07-30-2015, 03:32 AM #3
- May 2014
- 60
New member with print issue
