07-20-2015, 01:36 PM #1
- May 2015
- 49
Slicer/Marlin - How to get the extruder away from the print when a print finishes
I'm sure there has to be a simple way to make this happen.
Whenever I finish a print, the extruder is left sitting over (on) the finished print. Since no filament is retracted, and the head is still on the print, I get a gob of filament there. If I'm watching (which is often), immediately when the print finishes I use R-H's manual controls to home X, raise Z and retract some filament.
But this has to be a common problem for everyone. Is there some setting in Slicer or Marlin that will move the print head out of the way when a print finishes?
Thanks, Ira
07-20-2015, 07:29 PM #2
- Jan 2015
- 36
this is a simple thing to do in your slicing program (i use slic3r) there should be a section for custom G code at the beginning and end of the print .. simply seting a G code X,Y coordinate at the end will do what you want
07-21-2015, 10:08 AM #3
- May 2015
- 49
You know, I searched for this (more than once) in each part of all of the slicer config screens and looked right past it every time. Thank you - that's exactly what I was looking for.
07-21-2015, 10:31 AM #4
Open up Repetier-Host, load your .stl file, click the Silc3r tab and click "Configuration".
When the window opens up, click on the ""Printer Settings" tab and click "Custom G-Code" from the left side menu.
Make sure under the "End G-Code" section that G28 is listed there. G28 is your homing G-Code. That will move all your axis to the home position.
I think by default it says G28 X0, which means it will only home your X-axis. Y and Z will stay in the same place.
Try that and let me know how it goes.
07-21-2015, 11:42 AM #5
- Burnley, UK
- 1,662
Take care here. If your G28 Z position is 0 then you may end up driving your print into your head.
G28 XY will home X and Y only and leave Z where it is. If you want to move Z away then you should really do it with relative positioning as you will have variable height prints.
So:
These two can be on the same line, both executed together as stated above.
G28 X < home X axis
G28 Y < home Y axis
Switch to relative mode
G91
Drop Z by 30 mm from current position.
G0 Z 30
That should be safe for anything unless I have missed something.
07-22-2015, 09:34 AM #6
- May 2015
- 49
Thanks for all of the info. I had the command:
G1 X170 Y0 (X axis inverted on this printer)
that I wanted to insert, but for the life of me I couldn't find the place to put it (obvious once I was led to it).
Also good to know about the G91 command - I didn't want to "home" the Z Axis for the reason stated above, but now knowing about G91 I can safely raise the head regardless of where the print left off.
07-22-2015, 10:15 AM #7
