Results 1 to 8 of 8
Thread: Proprietary Filament Question
07-14-2015, 12:08 PM #1
- Jul 2015
I'm just thinking about getting a 3D printer but have heard some say that you have to buy proprietary filaments for the 3D printers currently out there. Is this true? Will I be stuck paying for expensive filament material if I get a 3D printer? Are there any 3D printers out there that use common sizing on their filaments? Are there any generic filaments out there that are still good quality that can be used on different models of 3D printers?
07-14-2015, 01:17 PM #2
To answer your questions:
No this is not true. Some 3D printers require the use of Proprietary filament cartridges, such as the Cube 3 or CubePro but most do not.
Again no, depending on the 3D printer you get. There are advantages to systems that use their own filament cartridges. It means that the 3D printer can keep track of how much filament is left and pause the print if it is close to running out (press print and walk away functionality) and the quality is standardised.
Most 3D printers use either 1.75mm or 3.00mm diameter filament. apart from that there may be restrictions on materials that can bee used by different printers dependent on whether you can control the printing environment e.g. heated bed, or the type of extruder.
Yes, most filament can be used by most 3D printers, dependent on the differences mentioned above. Quality is the main proviso. Always go for quality. We sell ABS and PLA filament which is of good quality and can be used by any printer.
The issue of filament proprietary cartridges should not be a major concern for you if you are thinking of getting into 3D printing.
07-15-2015, 02:27 AM #3
07-15-2015, 02:31 AM #4
07-15-2015, 02:55 AM #5
07-15-2015, 03:13 AM #6
There can be advantages to buying into a whole system, rather than building your own 3D printer system (model development to printing). If you are in business you do not want to spend your time trying to fit things together and make things work, you just what a whole procedure to work seamlessly, together. A good example would be switching to macs, your iPad seamlessly integrates with your laptop etc..
Integrated software can be an issue, obviously dependent upon the quality of that software. Filament cartridges are more expensive but the idea is that you have a standardized quality, the spool is designed to fit specifically to your printer and your printer can gather information on the state of your filament and what material it is. i.e. plug it in and the printer can automatically tweak its settings for th filament you have added. The printer can also pause itself if the filament runs out, you don't need to watch it all the time.
Like most things, there are advantages and disadvantages, costs and benefits, to the system you choose.
We have a conventional 3D printer that uses proprietary ink cartridges. Its more expensive this way, we could buy ink in bottles and fill up the ink cartridges if we wished, or even buy copies of the proprietary ink cartridges, but we don't. The reasons: Time, Quality. Buying substandard replacements at a cheaper price for instance is a false economy as we would not get the quality we wanted and so would end up doing it again or having to buy another cartridge all this also costs time.
BUT, we are not saying proprietary systems suite everyone or that they are always the best solution, the best system is the one that suites your needs
07-15-2015, 04:15 AM #7
- Burnley, UK
- 1,662
Also worth bearing in mind that the more control you allow the seller to have the less control you have.
Sony proved that with the PS3, sold one thing then crippled it so it no longer did what some people bought it for. You end up actually getting less and less for your money when you read the small print.
Open source rocks.
07-15-2015, 05:52 AM #8
Completely new to 3d printing and...
06-13-2025, 01:52 PM in General 3D Printing Discussion
