07-13-2015, 12:30 PM #1
- May 2015
- 14
Extruder motor won't drive while printing
So I have a LDM printer setup with a Rambo 1.3 board running Marlin firmware and Repetier host. I essentially built and setup the printer from the bones of an older, obsolete printer and I have everything setup except the extruder motor will not drive while it is printing. The printer does not have a hot end or heated bed, and I think somewhere in the firmware or settings there is an error not allowing it to print due to the thermal settings, but that is just my best guess. I can run the extruder manually using the manual control in Repetier, so I know everything is connected at least.
So far I have:
Disabled the temp sensors in Marlin by setting #define TEMP_SENSOR_0 0 for all thermistor inputs.
-Edit: I used a resistor connected to the thermistor to fool the printer into thinking the 'hot end' is at 189.4 C (hoping to fool it into thinking it is PLA), making the 0 a 2 in the above code
Set the minimum temp for the prevent dangerous extrude to 0 #define #define EXTRUDE_MINTEMP 0
-Edit: This was set to 180
Set the "Default Extruder Temperature" to 0 in the print settings in Repetier
I have tried to connect the thermistor to the board, but for some reason when it is connected the motors for all the axes don't receive any signal.
-Edit: This was also set to 180.
Edit: It does run the retract and extra length on restart settings while trying to print. It just doesn't run the extruder motor while it is executing a print job
Thank you,
-NickLast edited by Ncinquanti; 07-13-2015 at 02:17 PM.
07-15-2015, 02:02 AM #2
You are correct, I think most Marlin and other firmwares have the requirement that extruder temp exceeds 150°C to start extrusion. The motor is blocked until then.
I don't know how to bypass that.
07-15-2015, 01:09 PM #3
- May 2015
- 14
I got it to work. The filament diameter setting was not correct since I was not using a normal plastic filament. Thank you for the reply
Ender 3v2 poor printing quality
10-28-2024, 09:08 AM in Tips, Tricks and Tech Help
