Results 1 to 10 of 27
07-06-2015, 06:28 AM #1
Looking for a recommendation for further design software.
I keep hitting facet limitations on openscad.
So I'm looking for a free (so don't say rhino, autocad etc) design program with parametric abilities that doesn't fall over at 6000+ facets.
You try designing a golf ball or pin-board in openscad - just can't be done - at least I don't know how to do it without killing openscad in the process.
The more I look at the parent child command the less It makes sense.
So I need an easy to use cad program - that doesn't require any native artistic skills and can produce complex iterations at a pinch.
It also needs to be downloadable as the wifi in my workshop isn't brilliant and having to use web based packages just isn't going to do the job.
Does it exist ?
And if so - what's it called and where do i get it from :-)
