Results 11 to 18 of 18
07-02-2015, 01:57 AM #11
- Jul 2015
- 6
07-02-2015, 01:59 AM #12
- Jul 2015
- 6
07-02-2015, 02:00 AM #13
- Jul 2015
- 6
07-02-2015, 02:24 AM #14
- Burnley, UK
- 1,662
64 bit only :bawling:
Talking of 64 bit I hope you fixed the popup on start up telling me there was an upgrade and then it trying to make me install the 64 bit on my 32 bit PC.
I don't think I am overly bothered really, it works really well as it is (15.02), my only complaint is not enough adjust-ability to things particularly the support and no % done commands for repg both of which I can work round or live without by adding support to my drawings.
Even the old ones leave all the other slicers I've tried for dead, so much so that I am considering buying an Ultimaker if I land on one cheap. Being from the Northern UK it is unlikely that I will find one that cheap anyway.
07-02-2015, 05:51 AM #15
cheaper to buy simplify3d and build a cheapo windows machine :-)
I think I've got a decent brand new quadcore machine with ssd down to £180 all in :-)
(well that's the one I'm delivering to a client this afternoon) Could probably shave another £60 off if you use a 64gb ssd, build your own 'case' and don't bother with a fixed dvd drive (like my workshop 3d printer machine).
07-02-2015, 09:13 AM #16
- Burnley, UK
- 1,662
07-02-2015, 03:30 PM #17
- May 2015
- 39
07-03-2015, 02:18 AM #18
- Jul 2015
- 6
Check the dev blog, you'd see it. But the short answer is; Yeah. Its far more costomizable, but that will be stuff that you see in the future. There are tons of more settings that you can change. You can set bed size by changing the profiles. Tweak at Z was a comunity plugin and some people are working on it right now.
New member with print issue
