Results 11 to 17 of 17
Thread: thin wall test- failed
02-05-2014, 01:45 PM #11
Oh, offset is another issue entirely. I'm surprised that the rear wall is offset but the front wall is not - that sounds like it's in the code.
If both front and back were offset the same, I'd say you were losing movement, sometimes due to friction or not enough power on the motor that handles that direction.
02-05-2014, 01:59 PM #12
- Feb 2014
- GERMANY
- 16
I hope offset is the right word for my problem
It is so, that, in example Layer 25 is at y76 and layer 26 is at y76,3 and the layer 27 is at y76 and so on(only for example, i didnt read the code).
I have configured slic3r yet, but I have the problem, that my printer needs .x3g . Do I have only the possibility, to slice in slic3r, import in ReplicatorG and than export as x3g? It seems me to be awkward.
02-05-2014, 02:05 PM #13
Originally, I though you were saying your rear wall looked like this (cross section):
XXXXXX
XXXXXX
.XXXXX.
.XXXXX.
..XXXX..
..XXXX..
..XXXX..
..XXXX..
..XXXX..
..XXXX..
But now it sounds like you're saying it looks like this:
XXXXXX..
..XXXXXX
XXXXXX..
..XXXXXX
XXXXXX..
..XXXXXX
XXXXXX..
..XXXXXX
Is that right?
02-05-2014, 02:22 PM #14
- Feb 2014
- GERMANY
- 16
Yeah, but only in the upper half, like so:
xxxxxxx..
..xxxxxxx
xxxxxx..
..xxxxxx
xxxxx..
..xxxxxx
xxxxxx
xxxxxx
xxxxxx
02-05-2014, 02:33 PM #15
Right. Sorry, no clue.
If the front wall isn't doing the same thing, then it's happening because the code tells it to.
02-05-2014, 02:37 PM #16
- Feb 2014
- GERMANY
- 16
OK, I will check the code and will make the first print with slic3r tomorrow.
02-06-2014, 10:04 AM #17
- Feb 2014
- GERMANY
- 16
So, i solved the problem. Apparently, Im too stupid for slic3r (need a start.gcode for two extruders, which works with my printer). Therefore i tried it with Skeinforge 47 (Legacy). with 60mm/s same problem, but with 30mm/s i have all 4 walls perfect.
But what is the reason?
cu Ole
