Results 1 to 9 of 9
06-25-2015, 07:07 AM #6
With the help of S3D support I was able to figure out how to do this. This can be done in 1 process. You set the proper nozzle sizes for each extruder, set the smaller nozzle extruder as your primary at a layer res .1 (or whatever you choose) aswell as however many outside perimeters you want. Then on the infill tab, you set your larger nozzle extruder as the infill extruder, then set the "Print sparse infill every _ layers" Change this number to a how many perimeter layers you want to print per single layer of infill. So if I am printing .1 and want my infill to be .4 I would change that number to 4, however if I am printing .05 and want the infill to be .4 I would use 8.
