Thread: Marlin Error On Rumba
06-25-2015, 12:09 AM #1
- Jun 2015
- 6
Hello everyone! I am having a little trouble with Marlin on my Prusa I3V 12"
Essentially I have been reuploading the Marlin software to calibrate my new double extruder. It seems as though firmware artifacts have remained on the board after the numerous re-uploads of the Marlin software, causing unexpected results.First: the G29(Auto bed level) stopped working, then the homing (G28) command made the Z move up instead of down.
Any help is greatly appreciated.
07-06-2015, 05:06 PM #2
- 462
It sounds more like mis-configuration rather than firmware artefacts remaining. Are you sure you haven't reversed the Z axis travel direction in the firmware? Check your configuration.h for where the Z axis travel direction is defined (inverted or not) and for where auto bed levelling is enabled.
Search for
#define INVERT_Z_DIR
and for
#define ENABLE_AUTO_BED_LEVELING
07-06-2015, 08:15 PM #3
- Jun 2015
- 6
Thanks for your answer!
