Results 1 to 10 of 20
06-21-2015, 10:58 PM #1
- Jun 2015
Making printed circuit board (PCB) with Peachys UV Laser
Hello @ all
Just an idea.
Maybe you know that PCBs are made with UV Lighting and ACID for destroing the copper particular.
I think that this is one more usecase for the Peachy with uv laser.
Like in this Video - proof of conzept with laser ...
https://www.youtube.com/watch?v=x9WxdGmGvyY
or the traditional way for understanding how to...
https://www.youtube.com/watch?v=31ufQV9rh84
And the best ... afterwards you can print the housing for your PCB too ;-)
What do you think ?
Is peachys Laser able to do this in right scale and intensity?
BB Max
06-22-2015, 03:12 AM #2
- 219
The Peachy laser is not powerful enough to do that. A more interesting prospect (with less risk to eyesight) is to smear the PCB with the UV resin and print the pattern. The resin would hopefully adhere to the board and form the resist. Not sure whether the resin would form a suitable resist in terms of not allowing the etchant to undercut and not sure how you would get it off. But if it does work, this would be a brilliant way of making PCBs.
06-22-2015, 03:21 AM #3
- Burnley, UK
- 1,662
06-22-2015, 03:27 AM #4
- 219
06-22-2015, 04:01 AM #5
- Burnley, UK
- 1,662
06-22-2015, 01:56 PM #6
- Jun 2015
Hi again,
I also dont think that the peachys laser power is the neckbottle.
Also if its not so strong the longer we let the beam at one point the energy and uv emitting is kumulating the effect.
I think we can say the longer it is the stronger it is.
Its just to destroy the uv sensitive filmlayer, it dont has to burn it down or mill it away.
But maybe that you are right with eycare issue, maybe the copper is reflecting the beam and hits someones eyes.
I think the whole point is about calibration for exact measure and scale.
Also a point could be layout conversion from pcb design software and slicing software model ....
06-22-2015, 02:28 PM #7
- 219
If you just want to expose UV coated board, (not cutting the resist off), the Peachy should be able to do that relatively easily. I will certainly try that when I get my Peachy..... it's an interesting prospect.
06-22-2015, 03:10 PM #8
- Nov 2013
- Cambridgeshire UK
- 55
The PP29 was able to expose photo board ready for developing and etching, http://3dprintboard.com/showthread.p...-With-A-Peachy. The biggest problem was hysteresis in the mirrors but that should now be solved with in the V1.
06-23-2015, 03:19 PM #9
- Jun 2015
Oh Cool,
THX 4 the Link, so it can be done :-)
06-24-2015, 01:13 PM #10
- Sep 2013
- 308
Thanks for finding that Pete, cant wait to see how the V1 + imporved calibration software will make this work even better.
@mike_biddell
curing resin as a resist is a great idea, that way you dont have to pay extra for the UV sensitive boards.
I hope someone trys it and if you do I would recommend trying a supper low shrinkage resin.
