Thread: Advice on Bed materials
06-22-2015, 11:29 PM #1
- Jun 2015
- 13
I'm new to 3D printing and have my first printer coming tomorrow, a Duplicator I3
I was wondering what bed material should I be applying on the heated bed for the best results?
I will mainly be printing ABS as I need parts that can hold up at higher temperatures, but would also be interested in what to use for PLA too.
07-06-2015, 04:47 PM #2
- 462
I've tried BuildTak and at least one other advanced printing surface and neither have been particularly great - BuildTak sticks entirely too well until it's had a chance to wear in and the other surface was made of a plastic that curled up as the print shrank, defeating the purpose of the bed in the first place.
What I've had most success with is just a simple borosilicate glass plate, simply covered with a layer of glue from a glue stick. I've found this absolutely perfect for PLA and if the print sticks too well, a few minutes in the freezer and it will come right off. The same setup also works for ABS, although using an ABS slurry instead of glue helps.
