Results 11 to 15 of 15
06-18-2015, 07:15 AM #11
- Jun 2015
- 12
Can i ask, how are you guys accessing the firmware on these boards? I am relatively new to all of this, but i can get to it.
06-18-2015, 08:25 AM #12
- May 2015
- 6
You'll need to download and install Arduino IDE http://www.arduino.cc/en/Main/Software. Then head to the wiki or the github link, have a read through some tutorials to get your head around it.
http://reprap.org/wiki/Marlin
https://github.com/MarlinFirmware/Marlin
06-19-2015, 09:32 AM #13
- Jun 2015
- 12
ok, i was able to connect to the printer through the Arduino IDE but when i click on serial monitor i just get some status info, i can not figure out how to access the configuration h file.
06-20-2015, 08:59 PM #14
- May 2015
- 6
If you've got arduino installed, head to the firmware folder and double click on the file 'marlin'. that will open it up. Check the tabs at the top for the section you're after. Most likely configuration.h
06-21-2015, 05:50 AM #15
- May 2015
- 6
Jump on to here http://forums.reprap.org/read.php?406,507737,page=1 (probably shouldn't be linking other forums). You should be able to get some help here. We're all sufferers of the same pieces of crap from this crowd.
New member with print issue
