Results 21 to 30 of 74
Thread: Free build plate!!!!
06-16-2015, 11:25 AM #21
- Mar 2015
- Fenton, MI
- 63
Makerfarm Prusa 10 iV3. 254 mm squared
06-16-2015, 02:16 PM #22
- Jun 2015
- 34
ok lets make this the last one then
pm me an address
06-16-2015, 03:02 PM #23
- Burnley, UK
- 1,662
You got the size exactly right. No filing or anything, exactly the size of the aluminium plate so it slotted into the existing corners.
I need to pair the top off the corners as they are slightly proud of the bed.
Not tried it yet, other things on my plate right now.
06-17-2015, 01:53 AM #24
- Jun 2015
- 34
06-17-2015, 01:12 PM #25
- Jun 2015
- Norway
Hi, I'm new to this forum. Was just looking over the threads and noticed this, Am I to late? I have a Rigidbot Regular 260mmx280mm
Edit: No hurry, just read the labor part and all. Congrats!
06-17-2015, 02:00 PM #26
- Jun 2015
- 34
no worries, i will see what i can do. pm me your address
06-19-2015, 04:19 AM #27
- Burnley, UK
- 1,662
Hmm, tried it today and I am going to have to do some serious mods to use it. The expansion rate of the platform seems to be very high, much higher than the aluminium bed and because I have it held in by brackets at the corners the only place it can expand is upwards so I end up with a convex build plate with the middle about 3 mm high. This is really effective and sanding the end off the nozzles.
What it did print stuck well and more importantly came off easily it just didn't resemble the thing I gave it very much and at a set of nozzles per print it probably isn't really viable.
I shall peruse this and have another go when time permits but for now it's back to polycarbonate.
Grateful for it but gese am I glad I didn't buy one.
06-19-2015, 11:10 AM #28
- Jun 2015
- 34
a little disappointing but sounds like you gave it a good try. maybe others will have better luck
06-25-2015, 05:10 PM #29
- Burnley, UK
- 1,662
So I modded the printer to take the plate. Printed fine, no problem or warping, stuck well.
It stuck so well that I snapped it in two trying to get the print off.
I have peeled the diamond black top off the broken acrylic and stuck it to the polycarbonate that I normally use, I can't physically break that no matter how hard things are stuck so maybe it will be OK.
06-29-2015, 03:03 AM #30
- Jun 2015
- 34
i am glad to hear you did not give up on it lol.
maybe instead of acrylic i should be using polycarbonate.
if you are interested i would happily make you a polycarbonate version just for you to try
apologies on late posting of other build plates. i can confirm that
jetfish and soofle616 build plates have been sent friday.
