Results 1 to 8 of 8
Thread: last hope
06-15-2015, 01:08 AM #8
Are you sure you are using PLA? Those values are more in line with ABS (less shrinkage) than PLA. As a general rule the shrinkage for ABS is 0.7% so you will need to scale up your model by this amount before you slice either in your CAD software or in your slicer.
However if you are using PLA then I would suggest calibrating your extruder before continuing.
