Results 1 to 8 of 8
06-14-2015, 08:25 AM #4
- 110
I've got two:
(1) The "pin grid". This was something that I never could persuade the Makibox to print. It's designed to be printed upside down (ie pins downwards), and it tends to cause three problems. The first is that there are 25 small contact points with the bed, and if any one of them loses adhesion then the result is a mess. The second is that there's a lot of stopping and starting (moving between pins), and that puts a lot of stress on the extruder. The third is that there's a major overhang. I suspect that the Peachy will have no trouble with it.
(2) Buckyballs! This is six buckyballs, nested inside each other. Colours are just to make them identifiable. I was able to print a three-layer version on a Stratasys uPrint, using copious amounts of support material. I never got the six-layer version to print, because the STL file for it is too large for the Stratasys software to handle (around the 150MB mark, or 60MB at the coarsest reasonable resolution). It's not possible to print this without support material (because the six balls are not actually touching) but I'd imagine that the Peachy needs a lot less support material than any FDM printer.
If anyone is interested, I can put the relevant files on Dropbox.
