Results 11 to 20 of 36
Thread: Creating molds from 3D Printing?
01-22-2014, 07:31 PM #11
Thank you very much.
My 3D models (most them) are complex. So I'm thinking that a silicon mold will be the only way to get a good copy. navkram, just for curiosity. How many copies your silicon mold support with a sculpture with 20 cm tall? Polyester, polyurethane, vynilester Resin?
Thanks again. Excuse my english.
01-23-2014, 02:46 AM #12
- 27
You should be able to get a couple 100 copies depending on how careful you are with the molds and how well you take care of them (mold release) i am using a 2 part urethane air cure resin from alumilite.com
01-25-2014, 11:19 AM #13
01-25-2014, 04:39 PM #14
- Oakland, CA
- 935
I imagine some of the flexible materials the Objet uses could work as molds directly. But it would probably be more cost-effective to print a positive form and make molds from it, since you could make multiple molds from each model. I like the idea of 3D-printed mold boxes, though; that could definitely minimize the use of expensive mold rubber.
Andrew Werby
www.computersculpture.com
01-25-2014, 05:33 PM #15
- 27
01-25-2014, 08:08 PM #16
It's a interresting point. If this soft material from objet has a good mechanical and chemical resistance like as silicon rubber. Will be a great option. Otherwise. Why not make a silicon copy from 3d printed mold
01-28-2014, 10:20 AM #17
Check out my guide here on how to make a cheap waste mold and transferring your 3D print to wax for further finishing.
http://www.statueforum.com/showthread.php?t=142321Last edited by MeoWorks; 01-28-2014 at 10:22 AM.
02-03-2014, 03:39 AM #18
- 27
02-03-2014, 06:53 AM #19
Or you can just print the mold directly with silicone.
02-03-2014, 12:12 PM #20
- 27
