Results 1 to 10 of 25
06-08-2015, 03:40 PM #15
Unfortunately... I can't test this. I designed my probe to be stopped at the 'correct' location and my angles tell it to go just past that point. And the way the switch gets pressed, it kind of (very gently) tries to make the probe leg continue past the stop but it can't. As a result, that part of my mechanics is very consistent.
But even so... If your probe ends up in slightly different positions... If you don't have the probe going up and down for each point it should produce pretty consistent results. Going up and down for each point would not be ideal. Do you have the probe retracting and re-engaging for each point? If so, I think you want to put a stop to that!
