Results 11 to 15 of 15
Thread: How to make smooth surface
06-03-2015, 08:06 AM #11
- Jun 2015
- 7
Thanks. The printer uses something called "ABSplus thermoplastic". Does Acetone vapour help in this case?
http://www.stratasys.com/materials/fdm/absplus
http://www.stratasys.com/3d-printers...uprint-se-plus
06-03-2015, 08:19 AM #12
yep should be fine.
drop bassna a pm - he doe s a lot of vapour smoothing and will steer you straight time and equipment wise.
06-03-2015, 06:38 PM #13
- Jun 2015
- 7
Thanks.
What is the different between sanding cloth and sandpaper?
Who is bassna? He/she is not in this thread.
06-04-2015, 12:48 AM #14
- Burnley, UK
- 1,662
06-07-2015, 11:23 AM #15
- Mar 2015
- Fenton, MI
- 63
I just tried XTC-3D. It's a 2-part coating you paint on the part in a very thin coat. It's a self-leveling filler that dries clear. Here's a very quick, test spot I did. You can see some remnants of the lines because I didn't go for complete coverage, just a quick test.
Here's the backside of the part, no treatment
Here's the front side
I like this because I don't have to heat a volatile liquid, or even heat anything. It works on any material, and is very cost-effective.
I am in no way affiliated with the company that makes it.
