10-04-2013, 09:24 AM #1
Salt Water - Where do you get it?
I am curious. The salt water that is used in printing with the Peachy Printer; is it something you must get from somewhere, or is it a simple mixture you make at home using table salt and tap water?
10-04-2013, 10:03 AM #2
- Sep 2013
- 13
Salt and tap water, from what I understand.
I imagine there's a tiny chance you might need filtered water, if anything in your local tap water can mix with the resin and affect the print quality, but I doubt it.
10-05-2013, 05:02 AM #3
- Sep 2013
- Germany
- 47
Yeah, I think the "worst case" would be that you'll have to get distilled water (hardware store, supermarket) and salt without iodine or anti-caking agent (->organic food store or pet/aquarium store)
10-09-2013, 02:23 PM #4
- 52
You must import the salt water from the nearest ocean. As this is a Canadian printer it can use salt water from either the Pacific or Atlantic Ocean.
10-09-2013, 03:33 PM #5
- Sep 2013
- Saskatchewan, Canada
- 294
10-12-2013, 01:29 AM #6
- 52
Actually the artic water isn't compatible due to the ice. But hopefully in a few years that will no longer be a problem.
