Results 11 to 16 of 16
05-22-2015, 12:40 PM #11
- May 2015
- 31
I also found out the Flash Forge also has a control panel to let me turn off the lights from it, which is pretty handy. Just change the color to black and they turn off.
05-22-2015, 01:14 PM #12
- 441
05-22-2015, 05:16 PM #13
If you're into editing a long G-code file, you probably could insert the G146 command randomly throughout the file to produce many effects. Maybe a different color depending on the direction of the axis movements? (aka Disco 3D printing....)
Also, printing in the same room you sleep? Talk about "white noise"
05-24-2015, 01:05 PM #14
05-26-2015, 04:23 PM #15
- Apr 2015
- Northern Ohio
- 198
It's possible with enough gcode editing. I would be easier to just wire them to a controller like this one.
http://www.dx.com/en/p/rgb-led-light...B#.VWTj8kaX21k
That would give you full control of the lights, patterns, color and strobing effects, etc
05-27-2015, 10:08 AM #16
- 441
True, that could make thing's much easier :P
But I have been looking into the "Layer change G-code" editor in Simplify3D. I'm thinking there might be a way to set it up inside that. Set it to change a color at every layer change. Any idea's possibly? If I come up with something, I will come post it also.
