Thread: Help with a pseudo-Form1
05-21-2015, 04:17 AM #1
Hi guys,
I recently purchased a pseudo-Form1 (Chinese). I replaced the building platform, tank and resin materials with Formlabs original, but I cannot print anything.
As a test file I used this: https://www.dropbox.com/s/ffhhv3tshl...jango.stl?dl=0
What happens is that the work does not adhere to the platform and it remains a "blob" cured on the bottom of the tank.
The laser seems to work properly. I upgraded the firmware to the latest version without any problems.
Any suggestions on what might have gone wrong?
Many thanks!
05-24-2015, 12:19 PM #2
- Oakland, CA
- 935
I've had this problem
with the real Form1+. Try removing the build platform, cleaning it with isopropynol, and lightly sanding the aluminum with a sanding block, being careful to remove the resulting grit and oxides with more isopropyl. The other thing to try is increasing the preload against the tank; that's in Help/fine tuning. You can get it to press a little harder by lowering the platform, which seems to do a good thing. Also, positioning the prints so they're closer to the hinge side can help.
Andrew Werby
www.computersculpture.com
