Originally Posted by
Roxy
Play with the engage and retract angle... Move it a little bit either way and see if you can get it to quiet down. But before you do... Can you take a volt meter to it and see if the signal is high or low when it is sitting idle? If it is high... There may be a one line fix for you.
