Results 11 to 20 of 42
04-23-2015, 12:01 PM #11
- Burnley, UK
- 1,662
You need to read the link I posted and install the new HTML file. As it comes, deleting files is not done from the web interface directly, you have to stick a specific URL in with the file name in, a real ball ache. If you stick the HTML on that I have linked to then you can delete files from the main GUI and you can drag and drop to upload.
The 8 Gb is not limited to 8:3 format in the file name. That limit is imposed by the file system not the size of the card. What limits it is the web interface for some reason.Last edited by Mjolinor; 04-23-2015 at 12:12 PM.
04-23-2015, 11:40 PM #12
- Apr 2015
- Phoenix, AZ
What worked for me:
Downloaded the config app (FlashAirTool) from Toshiba's website.
Clicked "Network Settings", entered the following:
FlashAir SSID: MyNetworkSSID
FlashAir Password: MyNetworkPassword
Redirecting Function: ON
Enable "internet passthrough mode": Checked
Access Point SSID: MyNetworkSSID
Access Point Password: MyNetworkPassWord
<Apply>
Pull card, install in FlashForge
Check my router config, got IP address of 192.168.1.22. Obviously, your IP will differ (unless you also have 21 other devices on your network).
Hit that IP, saw the default folder listing (DCIM, MISC). SD_WLAN is hidden, so it didn't show, not that I cared.
Went to http://192.168.1.22/upload.cgi, uploaded my file, yay, printings.
Config file guts:
[Vendor]
CIPATH=/DCIM/100__TSB/FA000001.JPG
VERSION=F19BAW3AW2.00.03
CID=02544d535731364708df2a847800e801
PRODUCT=FlashAir
VENDOR=TOSHIBA
UPLOAD=1
APPMODE=6
APPAUTOTIME=1800000
APPNAME=Flashforge
APPSSID=tukedog
APPNETWORKKEY=************
LOCK=1
DNSMODE=1
BRGSSID=tukedog
BRGNETWORKKEY=************
The card seems to put the asterisks in place of the password when you save it. But it works.
That's how I got mine to go. Good luck.
16gb, model number: PFW016U-1BCW
04-29-2015, 10:59 AM #13
- Mar 2015
- San Diego, CA
- 107
It seems it does make a difference, but not due to the speed.
I received the 8Gb Class 6 card and find that "pass through" mode is disabled for that version. Manual says it is disabled for that card.
And I've been unable to get it to connect to my router as a client, despite setting APPMODE=5 in the CONFIG
ETA: I just noticed that Damon has APPMODE=6, so I will try that.
04-29-2015, 11:47 AM #14
- Burnley, UK
- 1,662
Here is my class 6 8gb config and it works fine:
[Vendor]
APPMODE=5
APPSSID=loft
APPNETWORKKEY=
VERSION=F24A6W3AW1.00.04
CID=02544d53573038470750016c4e00c901
PRODUCT=FlashAir
VENDOR=TOSHIBA
APPNAME=printer01
MASTERCODE=0013723642c6
LOCK=1
UPLOAD=1
UPDIR=/
APPAUTOTIME=0
DHCP_Enabled=NO
IP_Address=192.168.0.55
Subnet_Mask=255.255.255.0
Default_Gateway=192.168.0.1
Preferred_DNS_Server=192.168.0.1
04-29-2015, 12:25 PM #15
- Mar 2015
- San Diego, CA
- 107
Thanks. I will try that tonight.
04-30-2015, 10:41 AM #16
I've got the 16gb toshiba flashair w-02
I'll have a go with it in the knp next week - would save me running a usb cable round the dining room :_)
It wasn't an issue with file names - the toshiba software just doesn't allow uploading - well it didn't last time I tried it - admittedly that was sometime last year :-)
I'll do what MJ says :-)
04-30-2015, 02:25 PM #17
04-30-2015, 04:19 PM #18
- Burnley, UK
- 1,662
04-30-2015, 08:15 PM #19
04-30-2015, 09:42 PM #20
- Mar 2015
- San Diego, CA
- 107
Well, I finally got the mac to show up as an attached device in my router, but there is no IP shown.
When I connect to the assigned IP/upload.cgi, I get the upload page, but it refuses to upload the file, unlike when I connected directly to the card.
ETA: it finally uploaded the file Yay!
Just took a long time.
Not sure why the IP won't display in the router table.
ETA: seems to disconnect before or after uploading the file.
Thanks Mj!Last edited by robosmith; 04-30-2015 at 09:59 PM.
