Thread: FF Dreamer / Dremel Spool Size
03-19-2015, 03:49 PM #1
- Mar 2015
Does anyone know if the filament spools sold for the Dremel will also fit the Flashforge Dreamer? I have read the Dremel is a branded Dreamer with one extruder, but have never seen one in person.
03-20-2015, 12:31 PM #2
I think I read somewhere that they do, but even if not, there's an adapter on Thingiverse (which I use for my Dreamer) that lets you use a ton of different brand of spools. Its just a matter of the width of the spool and the diameter of the spool hub. http://www.thingiverse.com/thing:652415
03-20-2015, 01:35 PM #3
- Mar 2015
Thanks for the info. I use both Push Plastics and MakerGeek filaments. On both brands the spools are too wide to fit into the Dreamer using the printable spool holders.
04-27-2015, 05:12 PM #4
- Apr 2015
- Northern Ohio
- 198
BuMat released a full line of pla and abs for the dreamer.
05-01-2015, 07:19 PM #5
new spool holders, be sure to check out remixes
