Results 1 to 10 of 10
Thread: Where did all of the images go?
04-15-2015, 07:54 PM #1
- Nov 2014
- New Orleans
- 50
I am in the process of building my 12" i3v, and have been referring to a lot of the build threads here as I progress. I have noticed a lot of the images have disappeared in these threads, which I think would be immensely useful at the moment.
Specifically I am looking at how the endstops are installed, and was looking for others' examples of wiring. The routing and such isn't covered well in Colin's build guide, especially for the RUMBA electronics.
04-15-2015, 08:14 PM #2
- Mar 2015
- Palo Alto
- 63
3dprintboard seemed to have some kind of server meltdown a few days ago. it was down for a bit and then back with a really old backup before finally coming back for real. Maybe it lost the locally saved pictures in the process? I'm guessing the remaining pictures are newer or hotlinked.
04-16-2015, 07:29 AM #3
- Jul 2014
- Eastern Colorado
- 536
My Y endstop is mounted near the Y motor, and its wires are bundled with the wires from the Y motor and left Z motor. My X endstop is near the X motor, and I run its wires through the bottom slot of the upper X vslot rail, held in place with a slot cover.
04-16-2015, 02:12 PM #4
- Jan 2015
- 445
ABU, how did you change the Y endstop to the back of the printer? im sure its easy, i just dont know how
thanks
04-16-2015, 08:01 PM #5
- Dec 2014
- Canada
- 498
04-17-2015, 09:03 AM #6
- Jul 2014
- Eastern Colorado
- 536
04-17-2015, 04:03 PM #7
- Nov 2014
- New Orleans
- 50
Thanks for the feedback! I ordered a few m2.5 bolts to install the endstops similar to printbus, and hopefully I can get them all installed tonight. What is the benefit of having the endstop behind the printer? Does this change it from a positive max to a negative max stop? Any configuration changes necessary from the swap? Sorry if these are dumb questions, still learning (a lot) about the printers and how they print.
04-17-2015, 04:51 PM #8
- Jul 2014
- Eastern Colorado
- 536
For me, with the X endstop near RAMPS and Y endstop at the front, set as MIN endstops, every print came out facing the back of the printer. I could have just rotated the parts in the slicer to face forward, but I chose to move the switches and flip the motor plugs to achieve the same without having to think about it every time.
No changes were necessary to the firmware.
04-17-2015, 05:49 PM #9
Yeah, like AbuMaia said, I moved the endstops around and flipped the motor connectors over to reverse the motor directions so that I wouldn't have to make firmware changes to move home from the right-rear corner to the front-left corner.
I'm sure the MakerFarm intent with home in the right-rear is that the extruder can be moved out of the way after a print by homing the printer. I accomplish that through a few gcode commands added to the slicer endcode instead of sending the printer to home.
04-18-2015, 07:31 PM #10
- Jul 2014
- Eastern Colorado
- 536
