10-07-2013, 08:56 AM #1
How much light to cure the Resin?
Perhaps the MakerJuice guy could answer this, but does anyone know how much light is required in order to cure the resin? I could see there being an issue with drip vs. scan feed. We will have to get that right in order to make sure the resin is cured properly, right?
10-09-2013, 08:19 AM #2
- Sep 2013
- New Jersey, USA
- 494
Derek, the creators have answered your question:
Tech Question - What's the amount of light needed to cure the resin? I found the spectrum chart @ MakerJuice, but it doesn't say how much (J/cm^2? I'm not even sure what units would be good) is necessary... how to you set the drip feed vs the scan speed right so it gets cured correctly?
@Thor Johnson
The sensitivity of the resin is still changing as we develop it. The microphone records the drip speed, and the printer then uses that data to know how fast to print the object you are making. The program will recommend a drip rate that correlates with the size of your print, and the reservoirs you are using.
