04-08-2015, 12:12 AM #1
- Apr 2015
- 8
Help Needed, Strange Stringy print (Not overhangs)
I'm using the FlashForge Creator Pro and Simplify3D
On this print I'm now getting this stringy parts that I used to never get. Any ideas on what might be causing this?
stringy print.jpgLast edited by Arcadenut; 04-15-2015 at 06:25 PM.
04-09-2015, 06:37 AM #2
04-09-2015, 05:44 PM #3
I switched to Simplify3D last weekend and you may have the same thing I cant figure out. I am getting spider webs when my head moves from one wall over to the other. So I am playing around with the Ooze Control. Tried the Coast at end and didnt see a change.
04-15-2015, 06:27 PM #4
- Apr 2015
- 8
Ok, I solved this issue.
I had the wrong profile selected for the Process, so both Extruders where at temp. Once I switched the profile to the single extruder I wanted, it printed as expected.
04-19-2015, 11:15 AM #5
once i saw the pic - it was obviously a temperature issue - ie: too much of it :-)
04-25-2015, 04:14 PM #6
- Apr 2015
- Northern Ohio
- 198
Temp, speed and bed leveling/height are the first areas to look for that problem.
